It is currently Sun 24. Nov 2024 17:58:45
PostPosted: Thu 16. Apr 2020 4:17:17
Hi, i recently updated to 2.8 and am getting strange values with integration. Hooked up to desktop or via bluetooth everything is fine. For example my swash setup should be 120 degrees. On integration is says 135 degrees. Basically every value is not what it should be. It was working before and the only thing i have done is update fron 2.7xx to 2.8.should i look at updating integration firmware?
PostPosted: Thu 16. Apr 2020 6:16:11
you have to also use the latest Lua scripts.
Users browsing this forum: Flapflap, Helihello and 78 guests
