It is currently Sun 24. Nov 2024 17:27:16
 Post subject: Download link
PostPosted: Mon 13. Apr 2020 16:15:40
Hi Tomas
There seems to be somthing wrong whith the firmware 3.0.0 downloadlink.When clicking on it it opens up
in the webbrowser,and shows a unreedable signs.
 Post subject: Re: Download link
PostPosted: Mon 13. Apr 2020 17:30:32
worked fine for me
PostPosted: Mon 13. Apr 2020 20:55:23
latjo-k wrote:
Hi Tomas
I am guessing that you are using Windows OS with Explorer as your browser which rendered the same results on my screen. The firmware however did download into the "Downloads" folder which is the default folder unless you specify otherwise. If you use Google Chrome as your browser you will not see the gibberish on your monitor screen while downloading the firmware. Either way the firmware will download into folder you selected with either browser, but remember if your using Explorer you most like will have to change the file extension from .man to .4df.
BR,
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
PostPosted: Mon 13. Apr 2020 22:30:32
hi
Yes iam using win 10 and edge browser,but i have downloaded all previus versions without any problems,i
only have to rename the file from man to 4df.But now the browser Thinks its an html file,i havent done any
Changes to my computer or browser.
But if i rightclick on the Icon and chose save target as then it downloads just fine and whith the fileextension
4df. ????
For saftey i downloaded the file whith my pad and copied to the PC,so now the unit is updated to ver 3.0.0.
//Thanks
PostPosted: Tue 14. Apr 2020 9:00:30
hi again
Its very strange,if i in the url window type http://spirit-system.com/dl/fw//spirit-fw-2.8.0.4df
then the dialog window opens at the bottom of win edge and ask what would you want to do whith this file,
open,save and the fileextension is .man.
If i Changes the filename in the url window to 3.0.0.4df this happens.
Someone had a aidea?
PostPosted: Tue 14. Apr 2020 9:59:13
please try to load the web page again.
We hope it is fixed now.
PostPosted: Tue 14. Apr 2020 10:46:18
Hi
Now its OK.
Users browsing this forum: No registered users and 69 guests
