It is currently Sun 24. Nov 2024 18:39:03
 Post subject: Full System Check ?
PostPosted: Sat 07. Mar 2020 17:22:57
Hi folks
Does anyone know if there is any available software to run a full systems check / diagnostics check on a Spirit Pro ?
I am having some strange behaviour in that setting up a new heli (With an Spirit Pro that was involved in a crash)
Everything appears fine, bind my SAT, get everything dialled in via wizard or manually, then it appears when setting up Rescue mode - I lose all control between Tx and SAT (If I add in a Main Rx - everything is fine, but I lose the SAT connection) - Power off and on does not correct the lost connection...(even re-binding SAT does no work - Lights go from flashing to solid and Tx says successful - but nothing works in reality)
Would be nice if I could run some kind of diagnostics on the unit to confirm all is operating correctly to eliminate a systems fault - then it would mean the fault must be with me :roll: :roll: :roll:
Thanks in advance :D
 Post subject: Re: Full System Check ?
PostPosted: Sat 07. Mar 2020 22:22:05
are you sure your receiver type is configured for Spektrum DSM2/DSMX when using satellite?
You can perform BEC tester. System would show error in the Flight log if something is wrong or will not initialize at all.
Users browsing this forum: No registered users and 25 guests
