It is currently Sun 24. Nov 2024 19:22:02
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rescue question?
PostPosted: Wed 19. Feb 2020 22:56:49
jjuk wrote:
Cyclic ring looks low at 5 degrees, what heli is it?
Don't think that would affect a rescue climb though? Try increasing this to 9-10 degrees, make sure the servos are not binding at max/min pitch as you adjust it.
Noted
jjuk wrote:
Also, in a skids down hover, hit rescue. Does it climb?
It does climb and climbs well.
Quote:
Stabi -> Rescue collective pitch 47% (0% <-> -10%)
Not sure what happened here. I will check again this weekend then take it out for another flight.
Quote:
Servo Travel Correction
Servo Travel Correction -> Pitch (CH1) -> Maximum 14 (-64 <-> 64)
Servo Travel Correction -> Elevator (CH2) -> Maximum 4 (-64 <-> 64)
Servo Travel Correction -> Aileron (CH3) -> Maximum 2 (-64 <-> 64)
Servo Travel Correction -> Pitch (CH1) -> Minimum -5 (64 <-> -64)
Servo Travel Correction -> Elevator (CH2) -> Minimum -30 (64 <-> -64)
Servo Travel Correction -> Aileron (CH3) -> Minimum -5 (64 <-> -64)
Quote:
Can you get these to closer to zero by adjusting the link lengths with a swash leveller, are they required? That's quite a lot of correction.
Will check these again
PostPosted: Thu 20. Feb 2020 3:07:01
If its climbing fast in a skids down rescue, then I think increasing cyclic ring will help.
I think this is used to control cyclic roll rate.
If its too low it will take longer to rotate 180° before climbing. If this takes 1 second then that fits with your symptoms. Set to 10°, check for binding and go test it.
Also check 6° setting is correct.
PostPosted: Thu 20. Feb 2020 22:45:59
Just made some changes based on some of the above recommendations. Here's the revised .4ds file
21 Feb 2020 -.4ds [255 Bytes]
Downloaded 18 times
PostPosted: Thu 20. Feb 2020 22:47:07
And the rescue collective pitch is indeed @ 80% this time :D
Downloaded 21 times
PostPosted: Thu 20. Feb 2020 23:50:22
So is this still an issue? Is it flipping over faster now?
What happens if you increase acro delay to 3 seconds?
PostPosted: Fri 21. Feb 2020 22:51:32
Haven't flown it yet. Will do so this Sunday and keep you updated.
PostPosted: Tue 25. Feb 2020 18:17:27
Just flew my heli today and all is good. Rescue now works as it should :D
Thanks everybody for all your help esp jjuk :)
Users browsing this forum: Bing [Bot] and 20 guests
