For me this does not work at all. If I leave all transmitter settings unmodified and go to the spirit menu, I pick up no throttle/pitch channel movement at all with default spirit settings.
Then, (still in spirit app) if I reassign throttle from channel 1 and change it to channel 6 in the spirit settings... it picks up the _Pitch_ channel from my radio
So, I fiddled with it and it seems everything is working properly now... but it’s really counter intuitive:
1. I reversed the direction of the Throttle and pitch channels in the transmitter.
2. Also in the transmitter, I swapped the Original channel _output_ of Ch1=Pitch / Ch6=Throttle.
(So as it leaves the transmitter, Ch1=Throttle and Ch6=Pitch)
3. Now, finally this allows spirit to see them properly when (in the spirit app) the channels are again reversed and throttle is mapped to Ch6 and pitch is mapped to Ch1...
4. so basically there’s a double channel reversal going on which makes absolutely no sense to me. A reversal of a reversal should be identical to your starting point, but for me it definitely is not.
5. I’m thoroughly confused as to why this simple operation of channel assignment (which in the past has taken me all of 12 seconds to set up) is so difficult and has now occupied over two hours of my time in troubleshooting.
