Thanks a lot you perfectly answered what I needed to know.
Shonkonray wrote:
It is possible, but you have to change to another bank where you have selected rescue.
So if you press your rescue button you have to set your gyro channel negative (or activate the stabi channel if you are using this feature) AND switch bank to the one where you have selected rescue. If you release your button gyro channel and bank have to switch back to your normal mode. Thats all you need to do.
Example:
Bank 0: Stabi
Bank 1: Rescue
Rescue button inactive = Bank 0 and gyro negative (or stabi channel active)
Rescue button active = Switch to Bank 1 and gyro negative (or stabi channel active)
