It is currently Mon 25. Nov 2024 3:09:32
PostPosted: Tue 19. Feb 2019 12:06:21
I am currently setting up a Spirit Pro however I seem to h e an issue with the telemetry both spirit info and also the infor on the receiver screen which isn’t updating with RX voltage / frames sent or lost etc.
I have a DX9 running airwave 2.01 along with the latest spirit firmware. I read a thread from 2018 stating that 1.20 airwave was stable and working however I can’t get hold of this.
I am using Jeti integration cable and UNI cable purchased from the store. All servos can be controlled fine from the transmitter it’s just the telemetry we are not receiving. ESC is Align BL100A using latest firmware.
550x setup.4ds [255 Bytes]
Downloaded 31 times
PostPosted: Tue 19. Feb 2019 12:28:56
the RX voltage is not related with the Spirit unit at all. This must be wired out from the receiver - it has one pin for sensing the voltage.
The Spirit unit is sending ESC Status page and Flight Pack Capacity. These telemetry screens should be available.
Please see this page.
http://manual.spirit-system.com/index.p ... ntegration
Your settings are good, so the issue is not there. If you can't see any telemetry values, the only problem could be old firmware in the ESC. It is necessary to have the latest one and HobbyWing ESC. Sadly not all Align ESCs are compatible.
PostPosted: Tue 19. Feb 2019 12:43:18
It appears I failed to create the necessary telemetry screens in the transmitter. So all is sorted now. Thanks.
Users browsing this forum: No registered users and 72 guests
