It is currently Mon 25. Nov 2024 1:34:15
PostPosted: Fri 04. Jan 2019 12:07:33
I am setting up my new spirit pro. All components like servos, RX, FBL are placed on the desk. After initialization, the servos starts to move with strong shakings when I change the FBL unit orientation by hand. Is this a normal behaviour or should there a smooth movement of the servos?
Best regards
Walter
PostPosted: Fri 04. Jan 2019 14:57:31
The unit should respond to the movements. Once unit will be mounted at the model it will look very differently, because hands can't make smooth movements with a small things. So I am convinced it is normal.
PostPosted: Sat 05. Jan 2019 8:11:07
Ok. Thanks for quick reply. If I notice further servo shaking on mounted system I will contact you.
Users browsing this forum: No registered users and 45 guests
