It is currently Mon 25. Nov 2024 0:54:24
PostPosted: Wed 14. Nov 2018 18:03:30
Posted by accident in aero section yesterday..
I am finding that my new uSpirit which I haven't had off the ground yet, is doing some strange things on my oxy 2.
After some time, the swash will flick forwards and backwards a lot with barely any tilt of the device.
The sensor reading shows it fluctuating between + and - 75, for almost no movement of the heli.
Is this to be expected while on the bench?
YouTube video:
https://www.youtube.com/watch?v=6dKeA1lCoa4
PostPosted: Thu 15. Nov 2018 8:59:26
thank you for the video.
The behavior is not correct but it look like it could be caused just by position in which the model is initialized.
Can you confirm that when the model is powered up it is laying with skids down - for example at the table?
Eventually you could attach your settings file (4ds) for both banks.
It is possible that for Bank 1 there is some super high value configured somewhere in the settings, while for Bank 0 it is configured properly.
Backup/Bank Comparison will show you what parameters are different.
PostPosted: Thu 15. Nov 2018 10:01:01
Hello ZeXx86. Thanks for your help. When I am next at home and have some heli time I will check. It did it again once more right after that video, where I had re-powered the model. I was then on the ground trying to work out some vibrations indoors and it started to do the same. Then a little after that, I couldnt get it to repeat the same at all. I notice my gain was set unusually though (it was bound to a rotary knob on the tx that I was playing with.. the gain was at only -11% or something which would be an unusual number).
Next time it does it I will get the unit log and send over settings to you.
PostPosted: Tue 20. Nov 2018 21:26:19
ZeX, is it supposed to do this behaviour if it is inverted? If I hold the heli upside down it will do this same thing, every time. Is that normal when in Rescue or Stabi(normal) ? Perhaps that's what it does to get itself the right way up ? Regardless, while experimenting here just now, it did it again when right way up too.
PostPosted: Tue 20. Nov 2018 22:44:28
Just wondering if this is normal? : https://www.youtube.com/watch?v=jtWDIPei3XM
PostPosted: Wed 21. Nov 2018 15:54:48
Yes, this behavior is perfectly normal.
In the air the model will never stay at this position and immediately flip skids down. But since it is determining the shortest path to do so it is just changing direction.
PostPosted: Wed 21. Nov 2018 16:09:33
Thanks ZeXx86. I am still getting to grips with what is normal with this unit!
I accidentally hit rescue while in my tiny back garden this morning, and the thing shot off up into the air very high, and I panicked and brought it down with a quite smash :-)
I think I will change my switch configuration a bit.
PostPosted: Wed 21. Nov 2018 16:53:43
That is sad. You can decrease Collective Pitch so it is not aggressive at all. Also I recommend to use a momentary switch so you can engage the Rescue just for a fraction of second.
PostPosted: Wed 21. Nov 2018 16:58:42
It's OK! amazingly it only damaged the fibreglass canopy and couple of links and servo arms. Also the blades, but they are thankfully only plastic £5 blades.
I do have rescue on a momentary (bank 2), but I also have a 3-way switch for bank0/1/2 and I clicked it too far over.. I will reconfigure the radio tonight , and yes maybe reduce the rescue pitch.
It would have been OK if I was in a field, but I was in my small back garden and it just shot up right above my head.. :)
Users browsing this forum: No registered users and 68 guests
