It is currently Sun 24. Nov 2024 23:55:13
[ 6 posts ] |
PiotrS
Posted: Mon 08. Oct 2018 10:18:18 |
I have a doubt concerning Geolink alignment procedure. There is the sentence in the manual: Place GeoLink at a flat, aligned horizontal surface anywhere on your model in order to get a precise reference. (for example the Spirit unit). What about models without horizontal surface (leaning forward like Oxy 4)? Can do the procedure on table instead of the model?
Can I do the procedure on a motor (magnets) or it is not possible?
Best regards Piotr
Posted: Mon 08. Oct 2018 14:39:02 |
surface where the Spirit unit is mounted must be always horizontal (with respect to the model). It does not matter if model itself is leaned. This is just relative to the ground, but precise in regards to the model, main shaft, blades, boom. No, a table is actually not good, because it has different inclination than the model.
PiotrS
Posted: Mon 08. Oct 2018 15:41:00 |
Thanks. I wrote about a geolink, not a spirit unit.
The only surface I can make horizontal is top of the motor. Would it be OK?
Best regards Piotr
Wysłane z mojego VTR-L29 przy użyciu Tapatalka
Posted: Mon 08. Oct 2018 15:44:15 |
Yes, I replied in respect to GeoLink. GeoLink require very same flat and horizontal surface as Spirit, but just at the boom.
Motor could be good, but there are better places on the model such as Gyro (Spirit) mounting position.
PiotrS
Posted: Mon 08. Oct 2018 15:56:22 |
There is no chance to put the geolink unit on the spirit unit. There is no enough space between the frame panels.
I will try with the top surface of the motor.
Thanks for your fast help.
Best regards Piotr
urgno
Posted: Mon 08. Oct 2018 23:17:52 |
you could "extend" the inclination of the spirit using a small cilindrical object so then you can "level" the geolink over that object that of course will have the same level as the spirit control unit
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 39 guests |
