It is currently Sun 24. Nov 2024 20:58:57
PostPosted: Wed 29. Aug 2018 17:32:25
Hi all,
I have setup my T-rex 600 so far. It flies very ok, Pos hold is okay but alt hold is a mess.
Starting with vertical gain 100 gives vertical climb fast about 10m and then 10 m descending rapidly.
vertical gain 110 gives very high frequency ups and downs about 1m with 2hz frequency.
vertical gain 105 gives lower frequency ups and downs about 2m and 0,5hz.
Shall I try different setups between 100 and 105 or 105 to 110? Or much higher?
Appreciate your answers.
PostPosted: Thu 30. Aug 2018 7:07:38
I recommend to set value around 75.
This could help a lot.
PostPosted: Sat 01. Sep 2018 7:57:37
Trápil jsem se se stejným problémem jako pisatel dotazu . Nastavil jsem na mém T-Rexu 500X 70% zisku a je to naprostý luxus. :D
Logo 700,T-Rex 500X Dominator, Spirit PRO, GeoLink, Jeti DC-24
PostPosted: Sat 01. Sep 2018 9:13:33
Hä?
PostPosted: Sat 01. Sep 2018 19:41:38
I have tested my T-rex 600 now and finally set to "76". This was the best compromise. Thank you
Users browsing this forum: No registered users and 69 guests
