It is currently Sun 24. Nov 2024 21:05:35
PostPosted: Thu 30. Aug 2018 5:41:34
I have problems to connect my Frsky XSR receiver in the right way to use the opentx integration. Telemetry sensors are shown on the transmitter, but I didn't see any parameters to change options via transmitter.
Is it possible to show me the right way to connect the integration cable Frsky XSR -> Spirit? The S-Bus connection works perfectly.
Thank you.......
Greetings from Cologne,
Dirk
 Post subject: Re: FrSky XSR and Spirit
PostPosted: Thu 30. Aug 2018 7:08:59
Hello Dirk,
yes, you can find the scheme in the sticky thread in the Support section.
You can find it here:
viewtopic.php?f=20&t=2254
PostPosted: Thu 30. Aug 2018 14:03:07
I have connect the cables in the right way......
I solved the problem with an firmwareupdate of the receiver. The OpenTx integration works just now perfectly!
Dirk
PostPosted: Thu 30. Aug 2018 14:20:10
Thank you for your message!
Users browsing this forum: No registered users and 67 guests
