It is currently Sun 24. Nov 2024 17:32:31
 Post subject: uSpirit and Geolink
PostPosted: Fri 10. Aug 2018 2:51:38
The geolink connection on the sat port works, i have updated the uSpirit and Geolink firmware.
I am not able to bind the Spectrum satellite, I have the Spectrum adapter that has the small connector on one end and the servo connector on the other.
I connected the small port in the DSMX satellite port and I use a servo to small connecter adapter to connect to the rudder port.
Is that the right wiring?
Started the wizard and tried to bind. The light does not turn light on the sat.
I had the sat connected before to this unit and moved it to the rudder port, do I need to reset the uSpirit to bind on the rud port? I would loose all my settings if I reset the unit and would like not to restart from scratch.
Envoyé de mon iPad en utilisant Tapatalk
 Post subject: Re: uSpirit and Geolink
PostPosted: Fri 10. Aug 2018 3:58:54
After reading and listening to YouTube videos, it seems the satellite can be bound and then connected to other devices.
I did not try to turn the radio on with the “previously blinded satellite” connected on the rudder port, will that work? Was it that simple ?
I will test it tomorrow.
PostPosted: Fri 10. Aug 2018 13:16:42
It’s now simple when you understand it, I did the binding of the satellite on the sat port and move it with the spektrum adaptater to the RUD port and it works!
PostPosted: Mon 13. Aug 2018 7:58:51
You are perfectly right. You can bind the satellite anywhere, but in case of Spirit unit it should be plugged in the satellite port(s) for binding. In case of uSpirit it is the SAT port.
We will make this part more clear in the manual.
Users browsing this forum: Bing [Bot], mainstreet and 78 guests
