It is currently Sun 24. Nov 2024 17:55:46
[ 2 posts ] |
lukas82
Posted: Mon 09. Jul 2018 21:41:50 |
I have Taranis with X8R receiver. I connected receiver via SmartPort to SYS Port on Spirit Pro. Integration works fine I can see my parameters I can change them. I have hobbywing 60A V4 connected to spirit and it works fine as well, voltage rpm temperature. Everything is ok but pitch/collective dosent react, in diagnostic intergration menu it show that pitch is always 1% no mather what I make with stick. ELE, AIL, THR they work fine, but pitch is blocked to some value and doesn't react. When I pull out cable from receiver SmartPort everything is fine again, Pitch/Collective works. When I put cable in Smart Port no pitch reaction. I have no clue why integration mess with pitch...? Can it be some interference as I'm using 7cm extension on integration cable...?
Posted: Tue 10. Jul 2018 12:43:34 |
this is interesting problem. I guess that you are using PWM connection.
Did you tried to use simplier/safer SBUS connection? This could solve all the problems, since PWM has analogue transmission and can be interfered easily.
[ 2 posts ] |
Users browsing this forum: Helihello and 68 guests |
