It is currently Sun 24. Nov 2024 14:48:56
[ 2 posts ] |
omarb
Posted: Mon 23. Apr 2018 21:18:34 |
Need to trouble again. I started setting up a my g380kse and beach testing it, it shows raised and extreme tail vibes above 80 on aileron axis. This is is with no blades. I removed the tail blade grips and spindles and it's still the same. Any advice where else I should look. The previous owner supplied me the heli with a set of brand new blades as he said he had a tip over on the last flight. The damaged blades were still on the heli she I got it. The only change I made so far was to replace the brain with a spirit and the hobbywing esc's leads were very short and I damaged the esc trying to lengthen them, so replaced that with a yep 100 I had. Sorry for the long winded story but hoping any detail might help.
Thanks in Advance for any assistance.
Sent from my SM-G920F using Tapatalk
Posted: Mon 23. Apr 2018 21:56:13 |
usually when there is a crash in which tail is damaged in any way, the tail shaft can be bent and bearings can be bad as well.
If you are unsure, you can take a plot and upload it here.
Other than that there should be nothing else with Goblin.
[ 2 posts ] |
Users browsing this forum: mainstreet and 68 guests |
