It is currently Sun 24. Nov 2024 10:29:02
PostPosted: Tue 09. Jan 2018 2:39:31
I am using the Spirit Pro with DSMX satellite and want to set the stock Align RCE-BL50X ESC that came with the model kit. I have used a Spirit BE and set endpoints on a CC Phoenix Edge Lite 50A and was wondering if the procedure is the same with the Align ESC when it comes to setting the throttle endpoints or how to proceed if different.
Regards,
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
PostPosted: Tue 09. Jan 2018 8:06:09
the procedure is little bit different for nearly all other ESCs than for CC.
If you have factory defaults in the unit then it should usually work out of the box all correctly.
If the ESC was used to and is already calibrated, then you have to recalibrate it again by powering up with full throttle (at 100% TC) and then lowering (to 0% TC). This procedure is described in the ESC manual.
Make sure that Governor in the unit is not enabled while doing this.
PostPosted: Wed 10. Jan 2018 18:02:29
Thank you Tomas, it was a breeze to setup and your advice was greatly appreciated.
Regards & Have a Nice Day,
Kevin
Users browsing this forum: Amatrix and 53 guests
