It is currently Sun 24. Nov 2024 10:54:14
 Post subject: [SOLVED] Cyclic Sensor
PostPosted: Sat 06. Jan 2018 17:31:55
Hello Tomas. Have today with my 700er the cyclic sensor set to 95 percent and he flies noticeably more accurate than before with 65 percent. I could detect any errors in flight. Did you ever that the value is so high? LG Gernot
Greetings from Gernot
 Post subject: Re: Cyclic Sensor
PostPosted: Mon 08. Jan 2018 22:09:41
PostPosted: Mon 08. Jan 2018 22:16:30
with bigger helicopters it can work even with 100% gain in many cases.
But with very demanding maneuvers the servos can be loaded more. If you can't observe any bad behavior, then you can fly with this.
It has also impact on steering response.
Generally 60 - 65% is optimal.
Users browsing this forum: Bing [Bot] and 54 guests
