wow ZaXx86, thanks for such a quick reply
If you don't mind I will go over them one by one.
ZeXx86 wrote:
1) Yes, you can use it but you have to desolder all units and then it is still not too easy. We have also encountered some issues with Rudder ESC part.
For this reason we recommend to get dedicated ESC with similar specs. You can get one with BEC and other without BEC. or 2in1.
Sounds like this would be the better way to go (although a little more on that later), but for now would you by any chance or someone else, have a ESC w/BEC you could recommend?
ZeXx86 wrote:
You have to solder two cables where one will go to the AUX port (main rotor ESC) and other to the RUD port (rudder ESC)
Thanks for the parts of this you have provided but I think I am still confused.
I am guessing the reason the power to the two motors are coming out of the uSpirit unit is because of the governor system it can provide to those (?), with along I am guessing to Gyro control the tail motor, but then for one question...where then does from the main output power of the ESC go into? An for a second question, am I still looking to use any parts of the ESC to control the power levels to these motors? An if so how does that work (?), do I need to run a control wire from the Rx to both the ESC and the uSpirit unit so the uSpirit unit knows what that signal level is? Guess for a side question to that if in fact they both are working, how do they not conflict? An for one last one on that, should I shut off any form of Gov system if my ESC happens to have one?
ZeXx86 wrote:
2) You can simply add an external receiver of any brand - anything lightweight will work. There are some very light receivers. Without a cover it is even lighter.
Yeah I don't see that Futaba itself has anything small enough but via Hobby King I see there are some pretty small one and even with the sBus. Just have to hope they will work.
The only other thing to come back around to is I just wonder how much all this will add? Your unit is 9g, the smallest Rx I can find is 3-4g, and then with say a Talon ESC we are at about 5g. So just to be on the safe side we are 20g? For this I just weighed a replacement full Rec, FBL & ESC unit I have an it only came in a 8g total.
Anyway, guess there's no way to see the effect what ever extra weight could have in the end without trying it, but I have learned the hard way in the past that even very small amounts with things this tiny can have a big effect once airborne.
ZeXx86 wrote:
3) We can supply you cables with JST connectors - you can unsolder original and put it there.
Thanks, or perhaps see what you friend did?
Basically I have learned that for me to try to convert these kinds of connections just does not work. I neither have the patience, the eyes, or the time to do this to each connection and get them good or right and what would make it even worse is these servos in these things go often, so I think the only practical solution would be to find some adapters.
For this I have yet to find one, but there are dedicated places that make a lot of these types of things so perhaps they can make something up for me.
ZeXx86 wrote:
4) I can try to get some from friend.
That would be extremely helpful I think if you could, thank you very much.
ZeXx86 wrote:
5) The unit can work with all peripherals that we offer - we have Bluetooth modules and Wifi-Link modules. It depends what you wish. Both will work and all is described in the manual. For example here:
http://manual.spirit-system.com/index.p ... =Wifi-LinkYou can get JST-Servo adapter to connect it without any modification.
Package with unit contain 1x JST-Servo cable that will allow easy connection of the USB interface that is compatible with all our units. At the same time you will not need to work with small JST connector but just connect/disconnect normal servo cable.
USB interface is also in the package so you do not have to buy it. With the same adapter cable you can connect Wifi-Link or BT module. It can be powered from the receiver.
For Futaba receiver there is JST-RX (also in the package) so that you can connect it through SBUS.
Sounds like everything comes in the package and is good it does Wifi would probably be better as typically has better range and connection strength.
ZeXx86 wrote:
So what I recommend is to rather not use Align units and instead to get external parts such as receiver and ESCs. This must work as with any other helicopter.
All sounds good, and thank you for all the help you can provide.
