It is currently Sun 24. Nov 2024 7:23:10
PostPosted: Sun 20. Aug 2017 20:51:12
I'm starting to setup a new Logo 550 and trying to calibrate my TX to the FBL. I'm in the diagnostic screen trying to set end points and it is behaving very oddly. It seems to only respond to aeleron input and everything changes when I move the stick. It also takes about a second or two to update it.
I copied my TX setup from another model I have running Spirit and have tried two different RX's.
I'm running Open-TX with an X4R-SB on SBus to the Spirit.
PostPosted: Sun 20. Aug 2017 21:00:40
Are you talking about PC software or any other?
Diagnostic window is in the Spirit Settings, OpenTX integration, Android app, Wifi-Link and each is behaving little bit differently (as technically possible).
PostPosted: Mon 21. Aug 2017 14:17:55
Sorry. The Windows application.
PostPosted: Mon 21. Aug 2017 20:17:59
Ah, then it is possible that wiring is not OK.
I guess that you are using PWM connection.
Can you take a photo of the unit/receiver, please?
PostPosted: Tue 22. Aug 2017 11:24:37
Just figured it out. Forgot to use the SBus inverter.
My mistake. Thank you for the help.
PostPosted: Tue 22. Aug 2017 12:33:48
Ah, perfect.
Yes, smaller Spirit units require S-Bus Adapter for S-Bus.
Have a nice day!
Users browsing this forum: Bing [Bot] and 29 guests
