It is currently Sun 24. Nov 2024 1:50:27
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
PostPosted: Mon 05. Jun 2017 7:01:14
Hello Tomas!
Have tried all possibilities.But no result!
Please, after examining the problem, send the settings for Cosmic and for Spirit, Thank you!
Greetings, Gernot
Greetings from Gernot
PostPosted: Wed 07. Jun 2017 15:10:17
Hello Thomas. Do you know something new because of RPM at the Kosmik?
PostPosted: Thu 08. Jun 2017 9:37:28
I have found that there were some issues with RPM also with JLog from certain update.
The fix was to set Motor Pole to 2 and to leave default gear ratio in the Kosmik - 1:1.00.
In case of Spirit I recommend to set Gear Ratio according to your model (in the Spirit Settings) but to change Sensing Divider to 4 there. So changing sensor divider should do the trick.
