It is currently Sun 24. Nov 2024 1:53:39
[ 3 posts ] |
zr1100
Posted: Mon 05. Jun 2017 16:41:12 |
Does "Cyclic Gain" in "Sensor" tab affect banks that are enabled for normal stabilization and coaxial? If so, what is recommended for a starting point--ie. same as on regular flight bank with no stabi enabled?
PS--any tips on cyclic gain range in normal flying mode (disabled stabi) would be welcome also--currently set at 65--on 500 size heli. Thanks
Posted: Mon 05. Jun 2017 16:48:48 |
you can use the same value as for normal flying.
It is affecting both stabilisation and normal flying mode in the same way - higher cyclic gain - higher precision/stability. But Spirit can fly well even with the lowest cyclic gain - the feeling is just more natural. I do not recommend to go too high (over 70%) on this model. Usually value around 65% is optimal. But you can start with default (55%) with no worry.
zr1100
Posted: Tue 06. Jun 2017 19:20:06 |
[ 3 posts ] |
Users browsing this forum: No registered users and 43 guests |
