It is currently Sun 24. Nov 2024 2:10:45
PostPosted: Fri 02. Jun 2017 10:16:43
I am using a CC Phoenix 50 Lite and I have soldered a 10 ohm resistor between the wite and red wires, and plugged the esc into the Aux1 port on my Spirit Pro. Live Link has been enabled in the CC software.
I saved the changes before I disconnected the ESC.
Then in the Spirit software I put the gear ratio and pole number, my motor has 6 pole and I entered 3 in the software.
Then with my DS-16, I detected all of the sensors.
To start with I just wanted to see the Head Speed so I selected S RPM to be displayed.
Then I started up the heli, and no RPM was displayed.
What have I done wrong. I had the blades off and I have read in HF that the sensor needs the load of the blades to work, is this correct?
Where in the Spirit software do you set the end points for the swash plate servos?
I am changing over from another FBL and with that software you set the end points in the swash setup page.
The only end points I have found are for the tail.
PostPosted: Fri 02. Jun 2017 22:30:39
Hi, welcome to spirit
http://manual.spirit-system.com/index.p ... etry_Cable
It says 10 Kilo Ohm not 10 Ohm, the 10K is used as pull-up resistor.
Just to be sure, pols are number of magnets in the motor divided by 2.
Swash limit is called cyclic ring, there you set kind of mechanical limit, but don't go to high as high as you thing you need deflection, as it might cause boom strike on rescue with low rpm if value is to high.
regards, Adrian
Users browsing this forum: No registered users and 64 guests
