It is currently Sat 23. Nov 2024 23:22:57
PostPosted: Fri 03. Feb 2017 2:36:45
Hello.
I need to know how much current does the common servo bus support, because I'll use hv servos and will use Gryphon Quasar as bec.
Hitec rx specs says 15a using y-wires conected to bus, because each connector only handle 6-7a. Quasar has two of these connectors on on independen outputs to supply continuous 10a, 20a peak
Can I plug both outputs with y-cables to your unit, will the Spirit tracks support the total current or do I need to use a custom breadboard to supply the servos after Spirit's output ?
I'm using 3 BK 7001hv on cyclic and a 7006hv on tail servos on a three 600mm bladed Nex E8.
Marcos
Enviado desde mi Lenovo A7600-F mediante Tapatalk
PostPosted: Fri 03. Feb 2017 8:18:39
our units can handle 20A continuously and 40A in peaks.
It will work well with these servos.
You can put one BEC lead to e.g. AUX2 port and second to CH0 port, no Y-cable needed (depending on your receiver connection).
PostPosted: Fri 03. Feb 2017 11:15:01
Apreciate a lot your fast reply.
I'm not at all regretting about buying a Spirit.
Best support service I've ever seen for a high quality product.
Well done
Enviado desde mi MI MAX mediante Tapatalk
PostPosted: Fri 03. Feb 2017 11:32:17
No problem, you are welcome.
Users browsing this forum: No registered users and 46 guests
