It is currently Sat 23. Nov 2024 21:32:03
 Post subject: ServoTravel Correction
PostPosted: Thu 19. Jan 2017 1:39:12
How do you activate this to make the adjustments?? Mine remains "gray" and will not adjust anything.
Jim
PostPosted: Thu 19. Jan 2017 6:17:25
Move the pitch stick, you can adjust at full negative and at full positive only.
PostPosted: Fri 20. Jan 2017 15:14:15
Thanks. Why/when would I need to do this??
Jim
PostPosted: Fri 20. Jan 2017 23:55:30
Well, that correction is only to be used for some special cases of geometry which requires that. To solve small differences at top or bottom of swashplate travel compared to the mid-stick.
You don't use it to make the "regular" swashplate leveling.
Or did I misunderstand your question?
