It is currently Sat 23. Nov 2024 21:50:01
[ 4 posts ] |
jaffrie
Posted: Thu 29. Dec 2016 16:05:04 |
Think I finally got everything right. Manage to assign a trigger switch on my Jeti to activate rescue mode Have a couple of questions thought. 1. In failsafe menu are there any assignments needed ? I did nothing here so I assume if signal is lost heli will just cut throttle & other function will go into neutral position.
2. Rescue Mode : I set as Acro, when I trigger the switch swash goes up but when I invert the heli & flick the switch the swash just tilts so is this correct ? When I choose stabilised mode I notice that no swash movement when I flick the rescue switch. In this parameter does the rescue function works in a different way ? Lastly is it ok if I use the trigger switch instead of on/off type on my tx
Thks Tomas
Posted: Fri 30. Dec 2016 21:18:20 |
Perfect!
1) No, you only have to disable Failsafe in the receiver. Then failsafe from the unit will work. During the failsafe, the channels will return to the position when you clicked the Set failsafe button in the Channels window.
2) If you can see "HF" in the Diagnostic tab when rescue is activated, then the Rescue is working properly. Rescue will work well, if the basic settings were configured right - especially Position, Swashplate and all channels (rudder, aileron, elevator, pitch) are working in the correct direciton in the Diagnostic tab. Yes - stabilisation mode is not rescue, it is working in a different way when no collective is changed. Rescue is controlling also collective depending on the current model position.
jaffrie
Posted: Sat 31. Dec 2016 3:09:41 |
Hi Tomas Thank you again. Question, if I assign Stabilization Acro how does it work cause I've tried it & flicking the switch I see no movement of the swash so how would I know if it is working. Also in this parameter does it mean that if I'm caught up in disorientation etc by letting go of the stick heli will level out by itself or ?????. I read that lots are using stabilization to help train oneself so this is very good for me but nothing much has been written in depth about these parameters. Would appreciate if you could enlighten me on this
Cheers
Posted: Wed 18. Jan 2017 21:50:33 |
When you enable the stabilisation nothing should happen if the heli is laying on the ground. If you can see HF in the Diagnostic tab, then it is activated.
What you can see on the ground is a different stick response than for normal flying mode. This mode is used for learning the basics.
For helicopter recovery I highly recommend the Rescue mode which is also controlling the collective pitch. So you do not have to take care about anything, only the switch/button.
[ 4 posts ] |
Users browsing this forum: Bing [Bot] and 29 guests |
