It is currently Sat 23. Nov 2024 22:24:52
PostPosted: Sun 30. Oct 2016 0:27:51
Okay, I have a kosmik 160hv set to 8v and I want to run a buffer pack from the slave channel to keep it charged. I don't have the pro version,so I have to use a y adapter but where do I put it? I don't have an open spot on the Spirit, do I put the y adapter at the esc port? Or where, any help you all can give is appreciated? Thanks
PostPosted: Thu 03. Nov 2016 13:55:53
sorry for late response.
You can put buffer pack to your receiver if there is a free slot.
Alternatively you can use Y-cable such as this:
https://www.conrad.de/de/servo-y-kabel- ... 08394.html
You can connect it to the RUD port where it can feed servos well.
Users browsing this forum: No registered users and 64 guests
