I uploaded
this video w/ the hopes of trying to have this issue resolved as precisely and quickly as possible. Below is a problem description with additional details I thought may be helpful in troubleshooting my issue. I have gone through the
Spirit Tuning Guide and tried some settings found on a similar thread here(
How to tune out the annoying tail kick)
Problem Description:
Fairly straight forward. On spool up about 35-40% throttle the tail will spin out of control with very little to no rudder input from the transmitter. I have tried changes as noted below under “Notable Spirit-Settings” and “Notable Transmitter Settings (Futaba 14SG)” and the tail spin is still out of control. Any help/suggestions would be greatly appreciated.
Heli Setup
* Goblin 380 KSE (three blade rotor head)
* Motor: Xnova “Tareq Edition” 930KV
* ESC: Castle 100 lite
* BEC: 10 amp
* Cyclic Servos: BK DS-3001HV
* Rudder Servo: BK DS-5005HV
* FBL: Spirit Pro (Firmware: spirit-fw-2.1.0.4df)
Notable Spirit-Settings (Spirit Pro using default G380 Template from Wizard)
General Tab:
* Position: Horizontal (180)
* Swashplace: CCPM 120 (reversed)
* Receiver: SBUS
Sensor Tab:
* Rubber Common Gain: Changed from 1.0x to 1.20x
* All other settings left at default
Advanced Tab:
* Pirouette Consistency: Changed from 160 to 185
* Rudder Delay: Changed from 8 to 0
Notable Transmitter Settings (Futaba 14SG):
* Transmitter Rudder Gyro (GY AVCS): Changed from 100 to 90, 80, 70, 60
* Throttle Curve: Linear (Normal) // Did not test IDLE1
* Pitch Curve: Linear (Normal) // Did not test IDLE
If it matters, the receiver is: R7008SB (SBUS) w/ single cable from sbus port to RUD on Spirit Pro. If you need any other settings, please let me know. Thanks!
