It is currently Sat 23. Nov 2024 19:55:18
PostPosted: Fri 16. Sep 2016 20:14:01
After the 2.1 update my spirit won't connect with the app. It will connect thru the webserver ip. The Blue led is always flashing slowly even when connected to the wifi which I always do first.
PostPosted: Sat 17. Sep 2016 12:23:59
you have to also update the wifi link module.
PostPosted: Tue 20. Sep 2016 9:17:36
I did, will try again
PostPosted: Tue 20. Sep 2016 9:18:23
Im not getting a wrong version message
PostPosted: Tue 20. Sep 2016 11:05:37
That is strange. Is the module powered from the same power supply as the unit?
Is it connected as described in the Wifi-Link guide? Connection is very same as for the BT module.
PostPosted: Wed 21. Sep 2016 17:31:06
Yes, it used to work fine, but with 2.1 the app won't connect anymore
PostPosted: Thu 22. Sep 2016 10:44:37
I think that the problem is because you have received pre-production version of the module which was not configured in the same way.
I will send you PM.
PostPosted: Fri 23. Sep 2016 20:06:05
Answered your pm :)
Users browsing this forum: No registered users and 58 guests
