It is currently Sat 23. Nov 2024 19:42:50
PostPosted: Sat 20. Aug 2016 1:51:29
i have just installed my unused spirit on a new heli, firmware was at v1.0.25. and so i performed the firmware update.
I updated from v1.0.25 to v1.3.2 then on to v2.0.1, Rudder & Cyclic work fine but, i have no pitch function. The spirit diagnostics & Tx monitor indicate the THR & Pitch working fine but the servos do not move.
Thanks for any help.
Kim.
Spirit Warp 360. Spirit Goblin 500 Sport. Spirit Trex550 DFC. (BeastX Trex450, BeastX Trex550e... in Thailand)
Blade 270CFX, Blade 180CFX, Nano CP X BL.
neXt-Heli, DX9 B.E. DX6 G2.
PostPosted: Sat 20. Aug 2016 4:55:06
Make sure that your Rudder Gain is positive, if not, pitch output might be fixed if Rescue is enabled.
PostPosted: Sat 20. Aug 2016 9:48:25
Thanks for your reply, bailout not enabled at this time. i will try to flash to a previous firmware or even reset to factory settings if its possible.
PostPosted: Sat 20. Aug 2016 12:07:00
Factory reset will be the best. Please try to set Stabi/Function to Disabled. If it will help, then the rescue was engaged all the time.
PostPosted: Sat 20. Aug 2016 15:17:45
Finally ive managed to get it sorted, i flashed back to v1.3.2 which actually made things worse, i had no servo functions at all apart from the servos moving from the sensors, I decided to try a re flash of the v2.0.1, after a re boot everything is now working as it should. Goblin setup is almost complete just the bailout to do. :D
Thanks for help & suggestions.
PostPosted: Sat 20. Aug 2016 17:10:13
Why are you not using the latest FW? 2.02 I believe?
Users browsing this forum: Bing [Bot] and 69 guests
