Thanks Adrian-
I just ran two packs through the heli, all appears to be working fine including rescue.
However, your comments below make me want to double check something. Per Kontronik, this how the ESC and transmitter work together:
"The ESC works fine from 50-80%. Your Transmitter is than approximately 40-60 % open."
This presumes the formula 50% PWM + (XX% Tx throttle)/2 = YY% throttle to motor. For example, 50% PWM + (60% Tx throttle)/2 = 80% throttle to motor. So that's why I would not exceed 60% Tx throttle to keep ESC at or below 80%.
That is directly from their customer service rep.
With 2.0 on Spirit, is this approached differently?
Adrian wrote:
Andy the way TC works changed completly from 1.3 to 2.0
You tell Spirit whats 0..100% on diagnostics. Where hold is 0% and full is 100%
Normaly this matches -125 +125 in TX Monitor.
Next in spirit you tell Spirit, what it should send as lowest value to ESC (min Range) and whats full TC (max range)
this values are hard limits, think of TC servos in nitro which should not go over these limits as things might bend.
So, Spirit will match 0% to min rang value and 100% to max rang value.
Now, its obvious, lower -125 and higher 125 won't do anything.
Put 1100us and 1900us in range values, if your jive won‘t init, lower the min value, till it initiates.
In regards to your rudder issue, sounds like some mixer stuff.
I suggest to define a clean DX6 profile and reset the spirit walking trough config wizzard.
I did setup 3 models with 2.0 with no issues.
