ZeXx86 wrote:
if you have only swapped transmitter/receiver you do not need to change servo setup at all.
Everything should be same.
It seems that your servos are connected improperly.
CH1/CH3 are aileron servos,
CH2 elevator,
CH4 rudder.
most probably your ELEV and PIT servos are swapped. You should connect servos in the very same way as with your previous transmitter/receiver.
No, I swapped my RX2702v-d (Walera Devo FBL) with a GR-16 and Spirit, so I needed to connect everyting fresh.
Indeed it sounds like I connected the servos improperly, and I will check that again, when I am back. Just for fun I changed the cyclic phasing in my MZ-24 radio by 90° and it seemed like it was getting better, but I never tried 120°, which I believe would actually lead to the correct result.
Anyway, once I am back I will change the servo connections and retry and will keep you posted.
Michael
