It is currently Fri 22. Nov 2024 19:59:45
 Post subject: Goblin 380
PostPosted: Mon 13. Jul 2015 13:24:08
Hi all. Setting up a G380 with BK servos all round I intend to run 2800 3000 3200 HS.
Can anyone recommend a starting point for head & tail gain and piro comp.
Russ
 Post subject: Re: Goblin 380
PostPosted: Mon 13. Jul 2015 17:44:17
Hi Russell,
I recommend to start with default values, these are the best for the beginning.
Piro Consistency should be somewhere between 160 - 175 depending on your tail setup.
PostPosted: Tue 14. Jul 2015 9:58:46
Thanks Tomas can you advise what the default settings are for the G380 I don't remember seeing a preset for this one to use as a starting point.
PostPosted: Tue 14. Jul 2015 17:41:21
Generally you do not need to change anything special from Default profile settings. Only Piro Consistency, Rudder Delay and Geometry 6° should be configured with respect to your model.
If you can tell me what rudder servo do you use, I can tell you more accurate values.
PostPosted: Tue 14. Jul 2015 20:56:58
Russell is most probaply using BK 5005hv as tail servo. Or atleast I have it, as per manual show it too[WHITE SMILING FACE]
PostPosted: Wed 15. Jul 2015 7:23:22
Then the Rudder Delay can be configured to approx. value of 2.
PostPosted: Wed 15. Jul 2015 10:41:08
Yes Bk servos all round....I will try you suggestions.
Thanks Guy's
PostPosted: Thu 16. Jul 2015 10:12:45
Running 2800 3000 3200.
At 3000 the tail is perfect. Getting a slight wag at 2800 and 3200.
I have inspected the tail and made it smoother next I will check gov gain and see if this helps.
Russ
Users browsing this forum: Bing [Bot], MikeO and 47 guests
