It is currently Fri 22. Nov 2024 19:15:57
 Post subject: Governor RPM-signal
PostPosted: Tue 30. Jun 2015 12:57:07
I read somewhere on this forum that you could hook up the ground signal to the RPM-sensor cable from the ESC to the Spektrum connector on the Spirit FBL? Is this true? If so, do the middle pin on the spektrum connector (gnd) share the same ground as rest of the system?
The reason why I'm asking is because I had a lot of trouble getting the spirit gov working and when I finally did think I got it to work the ESC burned/fried...
ESC was a Jeti Mezon 130 RPM.
 Post subject: Re: Governor RPM-signal
PostPosted: Tue 30. Jun 2015 13:04:44
yes, you are right. Middle pin in the Spektrum connector has same ground as in the pin header.
You can also use Spektrum connector to power the RPM sensor if 3.3V is needed.
Users browsing this forum: 10x and 77 guests
