New version 3.4.1 released!
- Updated GeoLink Altitude Limit:
- Altitude Limit has configurable triggering Altitude in flight.
- Triggering Altitude is set by altitude from moment when the function is activated.
- Behavior is similar to Rescue (Automatic) from Spirit GT/GTR.
- When model will drop under configured altitude level, it will automatically engage rescue for 1.5 seconds.
- Supported with GeoLink v1 and v2.
- Updated GeoLink Return to Home:
- Hands-Free Flight when function is engaged.
- Once activated model will additionally maintain altitude configured by Return Altitude parameter.
- Model will start moving to Home position but at the same time will achieve desired altitude.
- Updated GeoLink Geo-Fence function:
- When Geo-Fence is breached model will additionally maintain altitude configured by Return Altitude parameter.
- Model will start moving to the center of geo-fence area but at the same time will achieve desired altitude.
- New parameter GeoLink - Return Altitude:
- New parameter for maintaining configured altitude when a GeoLink function is activated by a switch.
- Used by Return to Home and Geo-Fence functions.
- If configured to zero, then parameter is disabled.
- Value above 25m is recommended.
- JETI telemetry update:
- Telemetry variable S GPS Sat is updated also when ESC telemetry is unused.
- Anti-Gravity feature:
- Anti-Gravity feature is working also for Stabi functions.
- New HobbyWing Platinum v5 ESC telemetry:
- Full support for HobbyWing Platinum v5 ESC telemetry.
- See wiring and settings at the Wiki page.
- Spirit Settings - Setup Wizard:
- Goblin 500 - 580 preset was updated to support the latest SAB Goblin models.
- Goblin 700 - 800 preset was updated to support the latest SAB Goblin models.
Update for the Spirit units, JETI integration is available in our Download section.
WARNING: Please be aware that GeoLink's function Altitude Limit behavior has changed and Return Altitude parameter need to be configured.
