Version 2.4.0 was released!
It brings many new features and improvements:
- Support for μSpirit unit:
- Full support of the micro Spirit.
- Compatible with all peripherals.
- Can be used on helicopters of 130 - 250 size.
- Support for ESC/Motor driven rudder.
- New parameter Rudder - Control type to allow selection of the rudder drive.
- NOTE: Will be supported by Spirit Aero firmware.
- IMPORTANT: Older firmwares are not supported!
- Graupner HoTT integration:
- ESC Telemetry support.
- USB interface can be connected without repowering the unit - once integration cable is plugged off, the status led will be turned off and you can plug in the USB interface.
- Small speed optimization of the integration.
- Support for μSpirit.
- OpenTX Integration:
- Significantly faster telemetry data refresh rate.
- JETI Duplex Integration:
- Telemetry data rate was optimized.
- Support for Servo reverse CH0 for CCPM 90 swashplate.
- Support for Subtrim CH0 for CCPM 90 swashplate.
- In-Flight Vibration Analysis:
- FIX: Can be used with F: Stabi function.
- Can be activated all the time with no downside effect.
- ESC Telemetry:
- Support for telemetry data from the ESC - all data can be displayed directly in your radio.
- Available for JETI Duplex, FrSky/OpenTX, Graupner HoTT.
- New Telem CC, Telem UNI and Telem KONTRONIK telemetry cables.
- Castle Creations Phoenix and Edge:
- Battery Voltage
- Battery Current (experimental)
- BEC Voltage
- Consumed Capacity (experimental)
- ESC Temperature
- HobbyWing Platinum V4:
- Battery Voltage
- ESC Temperature
- Scorpion Tribunus:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- Kontronik Kosmik and Jive Pro:
- Battery Voltage
- Battery Current
- BEC Voltage
- Consumed Capacity
- ESC Temperature
- NOTE: All telemetry guides are available at the Wiki pages.
- Wifi-Link module:
- Support for the latest 2.4 firmware.
- Support for the ESC Telemetry.
- Support for the μSpirit.
- Improved detection of the firmware version with more clear messages.
- Spirit Settings - Android:
- Spirit Settings - FreeBSD:
- Launch scripts for better architecture detection updated.
- Stability was enhanced.
- Improved Setup Wizard:
- New schemes with μSpirit.
- Improved detection of the unit swapping..
- New Profiles: T-Rex 150, T-Rex 250, Oxy 2, Blade 130S, Blade 180CFX, Blade 230S.
- Governor:
- Sensor Activity analyser was improved to work with all governor sensors.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
You do not have to change any settings after the update from the previous version 2.3.
