It is currently Sat 23. Nov 2024 14:31:58
 Post subject: Version 2.2 released!
PostPosted: Tue 01. Nov 2016 20:09:28
Version 2.2.0 was released!
It brings many new features and improvements:
  • Brand new OpenTX (FrSky) integration:
    • Full integration with OpenTX-based transmitters, similar to JETI Duplex integration.
    • Computer is not needed at all!
    • Configuration anywhere and anytime directly in your radio.
    • Works with a different Receiver protocols - PWM, PPM, S-BUS.
    • Support for FrSky Taranis and Horus transmitters.
    • NOTE: OpenTX 2.2 required - will be available in the following days (Not released yet).
    • Big thanks for RCStudio that allowed to make this happen.
    • For more info please check the OpenTX integration guide.
  • JETI Duplex Integration:
    • Support for full configuration of the Channel Mapping.
    • Support for special functions configuration.
    • Support for programming Failsafe.
    • Telemetry Vibes value is calculated so that output is comparable to the Vibration Analysis.
  • Governor improvements:
    • Support for variable Autorotation Bailout settings in the Advanced/Expert window.
    • Optimization of the spoolup procedure when RPM signal is not clean.
    • "RPM Sensor data are lost" event is not logged during spoolup.
    • "Governor was activated" event logged also during Autorotation Bailout and Bank Switching.
    • Fixed kick for ESCs with very fast response on Autorotation Bailout activation.
    • Throttle output is smoothed when TC is under 50% to prevent violent spoolup.
    • Autorotation Bailout was reworked so it can achieve Requested RPM accurately.
  • Optimalizations for Spirit and Spirit (black edition) units:
    • Code was optimized to gain 7% performance boost.
    • Improved precision of the Rescue and Stabilisation modes.
    • Flight characteristics and precision closer to the Spirit Pro.
    • NOTE: It could be needed to reduce Gyro Gain by a few percent (5-10%).
  • Software enhancements:
    • Connection stability with the Wifi-Link module was improved.
    • Default profile in the Setup Wizard was updated.
    • Factory Settings values were updated (Rudder Delay is 8 by default).
    • Windows version has optimized performance and reduced size by 30%.
You do not have to change any settings after the update from previous version.
Only small decrease of the Gyro Gain for smaller Spirit units might be needed.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
opentx.pdf [712.57 KiB]
Downloaded 330 times
