It is currently Sat 05. Apr 2025 14:17:00
 Post subject: Version 1.2.0 released!
PostPosted: Fri 29. May 2015 19:55:15
Version 1.2.0 was released!
It brings many new features and improvements:
  • Governor support - Built-in governor with support for Electric, Nitro and Gasser helicopters!
  • Brand new Stabilisation - Significantly improved stabilisation mode with new possibilities.
  • 30 minute Logs - From now the unit can store 3 times longer flight events.
  • Spektrum SRXL - New protocol support in SRXL family.
  • Improved JETI model integration - Integration with Duplex is even smoother now.
  • Better calibration procedure - Calibration procedure can handle slower voltage rampup with various receivers now.
  • Sensor data processing - The way data are comming from the sensor is even faster.
  • Event capturing - Improved event capturing in the flight log.
  • Normal (Rate) mode - To fulfill needs of the scale pilots Normal gyro mode was updated.
  • Software updates - Various fixes and improvements were introduced in the software.
  • Flash procedure - Flashing process has double verification to make it even more reliable.
  • Spektrum Failsafe - Failsafe for the Spektrum satellites supports all available channels now.
  • Factory Settings - Factory settings were modified to make the tuning process even shorter.
Changes from previous version 1.1.0 in your settings:
  • All settings from previous version are untouched. You do not need to re-configure anything.
You can download it from our web pages!
Before flashing
To verify that the firmware was downloaded correctly you can use this online tool:
http://onlinemd5.com
Upload downloaded firmware file "spirit-fw-1.2.0.bin" from your HDD and then compare with the following:
c278ac87d7dc94832821d28873c703a6
PostPosted: Sun 19. Jul 2015 11:39:49
Updated version 1.2.1 released
This version fixes only minor issues:
  • Failsafe compatibility - Updated failsafe for SRXL/SUMD/UDI and EX Bus.
NOTE: For Jeti receivers we recommend to disable Failsafe there to allow Failsafe feature from the unit.
Before flashing
Upload downloaded firmware file "spirit-fw-1.2.1.bin" from your HDD and then compare with the following:
72caea2a900bb6ad8264a753f16a83d4
