ESC connection on spirit2 https://www.spirit-system.com/phpBB3/viewtopic.php?f=17&t=5791 |
Page 1 of 1 |
Author: | Martin.S [ Tue 22. Aug 2023 10:03:16 ] |
Post subject: | ESC connection on spirit2 |
got a 100a YPG ESC connected on aux1 on the spirit2 but engine no signal the FBL is connected with a duo BEC from Mateck systems 6V to the RX end 8.4V for the FBL and servo's all KST FBL works al servo's working but on aux 1 no signal for the ESC on the software put the channel mapping to cannel 3 like it is on the TX Frsky X20. disconnect the red wire from the ESC( power is running on the externe BEC) some one nows the problen or give me a hint. regards Martin |
Author: | ZeXx86 [ Tue 22. Aug 2023 10:05:28 ] |
Post subject: | Re: ESC connection on spirit2 |
Hello, please set Channel for Throttle to 1. I am not sure what is your receiver wiring but in the most cases it is Channel 1 in the Spirit. You should see throttle channel movement in the software in any case. |
Author: | Martin.S [ Tue 22. Aug 2023 14:43:29 ] |
reciever is a Jumper R1 sbus 16ch |
