It is currently Fri 22. Nov 2024 1:36:41
PostPosted: Mon 12. Jul 2021 14:06:29
Good Afternoon
Configuring the Spririt RS as "" rescue ( normal ) "" my helicopter doesn't turn, so that the skids are facing down to earth.
Instead the Goblin stays upside down and is sinking slowly downward...
What did I do wrong ?
transmitter DC 24 Jeti
Spririt RS SW 3.3.1
Kind Regards
p-51d
PostPosted: Mon 12. Jul 2021 16:26:55
probably Rescue is not activated at all.
Or your basic settings are configured incorrectly.
I recommend to verify if all servo arms are in the middle when you enable Servos/Subtrim (tuning) menu.
At the same time swashplate should be leveled. And also there must be zero pitch between main blades.
PostPosted: Tue 13. Jul 2021 9:37:24
Hi ZeXx86
Thanks for your answer; I've to check on your points and let you know ;
It probably takes a while as we'll have very heavy rains the whole week...
Kind Regards
Roland
PostPosted: Tue 13. Jul 2021 10:17:19
Hi ZeXx86
in the setup of the GeoLink there is a check box under "settings" : "POSITION HOLD"
Do I override the SPIRIT RS cfg when checked ?
( this would explane the staying of the helicopter upside down )
In the SPIRIT RS setting there can be set the priority of the sticks ( range 0-16 )
When I want to have at least half of the controls ( i.e. the pitch ) what number should I choose ?
Does " 16 " mean full control ?
Kind Regards
Roland
PostPosted: Wed 14. Jul 2021 13:18:13
when Position Hold feature from GeoLink is used, model will remain at the single position. But first you have to enable it. It does not matter if Rescue is enabled or disabled. It will not move in horizontal axis.
If you want to be sure no other function is affecting Rescue, please turn everything else off and retry.
It is possible that you set Acro Delay parameter. If it is not 0, then model will fly like with Rescue (Acro) for period configured in this parameter. Then it will return to skids down when period will pass.
Stick Priority is affecting how much you can control the model (Cyclic) with sticks during rescue maneuver. Default value (6) should be good. Usually pilot should not need to control model at all during rescue. Default value is recommended if you are not sure what is good for you.
Users browsing this forum: No registered users and 18 guests
