Setup limits - on the Spirit or on the Tx? https://www.spirit-system.com/phpBB3/viewtopic.php?f=17&t=4133 |
Page 1 of 1 |
Author: | alex4orly [ Wed 08. Jul 2020 13:31:43 ] |
Post subject: | Setup limits - on the Spirit or on the Tx? |
I am new here and need to learn to hover first. I want to set my Pitch range to : -5, 0, +8 Can I do that somehow on the Spirit Limit tab or only on my Tx? Thanks for any guidance |
Author: | urgno [ Wed 08. Jul 2020 14:08:30 ] |
Post subject: | Re: Setup limits - on the Spirit or on the Tx? |
you can do that in both places but in my opinion is better to set the maximum pitch available on spirit ( +-10 / 12° depends on your mechanic ) then you setup the pitch curves in your TX so you can choose with a switch what curve to use |
Author: | xoexoe [ Wed 08. Jul 2020 14:48:08 ] |
I believe that setting is on the Limits tab. I agree with the post above. If you’re a beginner then do something like –10 deg / +10 deg, or –12 deg / + 12 deg. I’ve been flying 2 years and 12 degrees is plenty for me. Use pitch curves in your TX to then get the actual desired pitch range. |
Author: | alex4orly [ Thu 09. Jul 2020 8:08:02 ] |
urgno wrote: you can do that in both places but in my opinion is better to set the maximum pitch available on spirit ( +-10 / 12° depends on your mechanic ) then you setup the pitch curves in your TX so you can choose with a switch what curve to use Yes, that is how I did it Thanks |
