ZeXx86 wrote:
you might check if Geometry 6° parameter is configured correctly.
If it is too high, it can introduce oscillations.
You can easily go down with Cyclic Gain to 25% without a risk. But generally 50% should work everywhere with a normal setups.
Thanks. That did it. I think I tuned the geometry when going through the wizard stages with my digital pitch gauge.
When I went back into settings today the value was showing 8° though!
I reduced it to 6° and went flying. I had a very slight wobble while spooling up but nothing I haven't seen with other big birds. Once the headspeed is at a decent level I had no wobble or visible vibrations anymore. Cyclic gain is at 45% for now.
Sadly the vid was made from afar and quality is very bad but in my opinion it looks quite ok. I'll still have some finetuning to do but this is a sold base to start from now.
https://www.youtube.com/watch?v=KI8R5p4GpG4
