It is currently Fri 22. Nov 2024 1:37:27
 Post subject: Stabi - rescue duration
PostPosted: Sat 28. Dec 2019 16:43:22
Hey guys- It looks like "rescue duration" and all the settings under it are missing from the manual.
http://manual.spirit-system.com/index.p ... #STABI_TAB
Is this setting a time that the heli will "rescue and climb" before then using the "hover collective pitch %" to attempt to hover?
(e.g. the 3rd post here: viewtopic.php?f=24&t=1125)
Thanks guys.
PostPosted: Sat 28. Dec 2019 18:42:07
Yes you are correct.
PostPosted: Tue 31. Dec 2019 10:34:46
Manual was updated.
Also you can find description always in the Spirit Settings when you hover mouse over a parameter.
PostPosted: Mon 04. May 2020 22:51:30
Does rescue duration include acro delay?
Or is it additive?
E.g. acro delay + rescue duration = time until it hovers?
Or
Rescue duration = time until it hovers?
If the 2nd is true, then it is impossible to have rescue duration less than acro delay.
Users browsing this forum: No registered users and 17 guests
