Spirit System
Stabi - rescue duration
https://www.spirit-system.com/phpBB3/viewtopic.php?f=17&t=3694
Author:  jjuk [ Sat 28. Dec 2019 16:43:22 ]
Post subject:  Stabi - rescue duration
Hey guys- It looks like "rescue duration" and all the settings under it are missing from the manual.
http://manual.spirit-system.com/index.p ... #STABI_TAB
Is this setting a time that the heli will "rescue and climb" before then using the "hover collective pitch %" to attempt to hover?
(e.g. the 3rd post here: viewtopic.php?f=24&t=1125)
Thanks guys.
Author:  LogoX2 [ Sat 28. Dec 2019 18:42:07 ]
Post subject:  Re: Stabi - rescue duration
Yes you are correct.
Author:  ZeXx86 [ Tue 31. Dec 2019 10:34:46 ]
Manual was updated.
Also you can find description always in the Spirit Settings when you hover mouse over a parameter.
Author:  jjuk [ Mon 04. May 2020 22:51:30 ]
Does rescue duration include acro delay?
Or is it additive?
E.g. acro delay + rescue duration = time until it hovers?
Or
Rescue duration = time until it hovers?
If the 2nd is true, then it is impossible to have rescue duration less than acro delay.
http://www.phpbb.com/
