It is currently Fri 22. Nov 2024 5:07:12
[ 5 posts ] |
nzflyer
Posted: Tue 06. Oct 2015 9:11:09 |
Joined: Sun 04. Oct 2015 9:55:42 Posts: 33 Location: Christchurch New Zealand
Hi. Just want to know what setting to adjust to stop my tail blowing out counter clockwise when flying tail in. When i hit rescue or go from negative pitch to full postive the tail blows out from 6 o'clock to 4 o'clock. Any advise would be great cheers.
Sent from my iPad using Tapatalk
Posted: Tue 06. Oct 2015 10:20:55 |
this problem is mostly caused by: a) tail has too low angle (rudder end-points should be increased if possible) b) head speed is too low so the rudder is not able to mechanically compensate the force. c) Pirouette consistency value or Gyro Gain is too low.
Can you save your settings to the file and attach it there? What is your helicopter and tail servo?
nzflyer
Posted: Tue 06. Oct 2015 18:21:44 |
The heli is an align 550 dominator. My head speed is 2300 which should be fine. I will increase the gyro gain and redo end points. And see if that helps. I'm pretty sure i can get so more movement in my end points on the tail.
Posted: Wed 07. Oct 2015 7:13:57 |
Ah, you should set the highest possible range if that is not a problem else tail will blow out.
nzflyer
Posted: Wed 07. Oct 2015 10:23:44 |
I also found. My one way bearing was playing up. Was locked up. Not sure if that was affecting it. As well. Have adjusted tail.
[ 5 posts ] |
Users browsing this forum: No registered users and 5 guests |
