It is currently Fri 22. Nov 2024 0:55:16
PostPosted: Sat 18. May 2019 15:29:41
this is my first spirit and i try to use it in a Raptor E550 stretched with 600er Tail.
Hobbywing 120A V4 connected to Spirit for Gov and Telemtry
Radio is a Taranis X9E.
Fly with 1550 RPM
Spirit is the Pro version with lates FW.
Also installed is a Align DFC FBL Head.
I want to fly in position mode all the time. (I want to get the same feeling like the old HC 3A in Horizont mode)
All Setting before first flight are done and looks OK. And i set all setting&parameter to the recommend values.
The first flight began Ok but after ~1 Minute the Heli shakes. The vibration (fuel) shows 90%.
I can land the helicopter save but much longer and he was history.
First i check for static discharge and loose Parts. I can t found anything.
I start a second flight now with gyro settings 45. The heli start with shaking after some heavier cycle inputs.
I reduce the gyro settings via taranis to 35.
Now the flight was more stable but the helicopter was nervous on input.
On this day it was windy ~15-20 km/h.
My questions are:
1. Why i must reduce the gyro setting so low?
2. Why the fbl is so agressive on input?
3. Can i initialyze the fbl in position mode and fly all the time?
4. any suggestions for better seetings. Flight style is beginner with no 3D
Andreas
PostPosted: Sat 18. May 2019 15:39:20
here are my settings
PostPosted: Sun 19. May 2019 22:05:06
probably you missed other important settings. For example Geometry 6° which is probably configured incorrectly.
You can start with a stabilisation mode.
PostPosted: Tue 21. May 2019 6:22:49
thanks for reply.
I will check all the values again and report here for further actions.
Andreas
PostPosted: Tue 02. Jul 2019 15:13:07
Sorry for the realy late answer, but today i got my first free time (long enough to do that)
I write everything in a document and i hope i have all necessary stuff inside.
Raptor E550 Spirit.pdf [1.35 MiB]
Downloaded 142 times
PostPosted: Sat 06. Jul 2019 10:20:50
today is windy 30 km/h
But i want to try a testfliught and i hope with the settings below the system works.
Andreas
PostPosted: Tue 09. Jul 2019 6:20:22
the new flights are sucessfully. just only fine adjustment needed.
But sorry for the hard opinion:
The hardware is very good, the software is good, the shop and shipment is good but the Forum here is the worsest part in this chain.
No or late response are not helpful.
Here you can make some good improvements.
Andreas
PostPosted: Tue 09. Jul 2019 7:11:32
Write your contributions to the English part, not to the Czech one. The answers will be faster.
PostPosted: Fri 19. Jul 2019 13:28:19
I am afraid but the question was put in a wrong forum subsection.
This section is used only for sharing configurations with other pilots.
Users browsing this forum: No registered users and 10 guests
