Gaui X3 - UPDATED https://www.spirit-system.com/phpBB3/viewtopic.php?f=17&t=265 |
Page 1 of 1 |
Author: | Jman841 [ Thu 11. Sep 2014 8:59:42 ] | ||
Post subject: | Gaui X3 - UPDATED | ||
Gaui X3 ZEAL 350mm Main blades Zeal 62mm tail blades Xnova 2618-1860kv 13 degree's of pitch Hobbywing Platinum V3 50amp ESC TGY 306G HV's all around on 6v Flight style is 3D and Hard 3D Bank 1: Sport and Smooth 3D Bank 2: 3D and Hard 3D Bank 3: 4s setup run at 2400 rpm Enjoy!
Author: | zorem [ Sun 14. Sep 2014 13:57:51 ] |
Post subject: | Re: Gaui X3 |
I am going build Gaui X3 these days. Do you have Spirit FBL instaled with servocable forward or backward ? I would like use your setup. Thanks. |
Author: | Jman841 [ Mon 12. Jan 2015 23:02:08 ] | ||
Post subject: | Re: Gaui X3 | ||
Sorry for the late reply. Just saw this. Currently cables are to the rear of the heli. I have changed a lot since that intial setup and tuned my X3 much more. I am very pleased with how it is setup now. Bank 1: Sport and 3D flying Bank 2: 3D and Hard 3D flying (my most used bank) Bank 3: 4s setup for low HS flying (at 2400 rpm) (I updated the main post as well, both are the same file)
Author: | Bjoern_ve [ Sat 21. Feb 2015 21:51:17 ] |
Post subject: | Re: Gaui X3 - UPDATED |
HI, I am very interested in your setup because I have problems with my tail. It begins to tremble at backward flight and I'm not sure at what setting should I turn. My head speeds are 2600-3000 rpm. When I look at your setup to me then I see no difference between the individual banks, can you tell me where the differences are? Can you maybe give me a few tips? Setup: 3x TGY306 on Head 1x TGY306 on Tail on 6V Align 460MX on 6s on 6V ESC Castle Phoenix ICE 50 Blade:Align 360 Tailblade: Align 68mm on the Tail is the belt upgrade Björn |
Author: | ZeXx86 [ Sat 21. Feb 2015 22:05:58 ] |
What is the length of ball linkage on the rudder servo horn? I recommend the closest hole. Very important is also Piro Consistency parameter. |
Author: | Bjoern_ve [ Fri 06. Mar 2015 12:46:15 ] |
Hello, I now have the linkage so transformed that I use the first hole. However, I now have the problem that the tail no longer holds in high pitch and it turns away about 90 °. It then appears in the log message on the Rudder Limits reached. I'm going to experiment with the distance of the linkage and so try the best results achieved. Are there any other tip I could try? Björn |
Author: | ZeXx86 [ Fri 06. Mar 2015 13:46:58 ] |
Hello, make sure that you have readjusted rudder end points and that your gyro gain is configured properly. |
Author: | scrambled [ Sun 03. Jan 2016 17:22:57 ] | ||||
Post subject: | Re: Gaui X3 - UPDATED | ||||
If anyone is interested, my X3 settings with (regular) Spirit v1.3.2 Spirit rescue and governor is in use. - Belted tail - HW50A v3 - Align (6S) 460MX dominator motor - 3x KST DS215MG - KST BLS505X - Align 360mm CF mainblades - Align 68mm plastic tailblades
