It is currently Sun 24. Nov 2024 7:41:13
[ 3 posts ] |
sacha
Posted: Sat 30. Apr 2016 16:56:56 |
If you are using a spirit pro on your velos880. Please share your settings.
Sacha
sacha
Posted: Thu 26. May 2016 19:35:48 |
No one willing to share the velos880 settings ?
I installed the 3 blade tail upgrade and now have some tail oscillation. Increasing or decreasing the gyro sensitivity between 70 - 100% does not solve the problem.
Thanks for your help
Sacha
Posted: Fri 27. May 2016 7:54:43 |
Reducing Pirouette consistency should help if you are observing oscillations just in a demanding manouvers.
There are not too much people that are flying with Velos.
Also make sure that the new upgrade is working really smooth. You can try this in the way, that you unmount all blades. Then disconnect push rod from the rudder servo so you can move it by hand. Then you have to start the motor to your flying RPM.
When the motor is spinning, try to move with the push rod - it should be very smooth in the whole travel range. Nearly same as when the motor is not spinning.
[ 3 posts ] |
Users browsing this forum: No registered users and 15 guests |
