It is currently Fri 22. Nov 2024 12:27:02
 Post subject: Voodoo700 - Low RPM!
PostPosted: Thu 05. May 2016 7:53:39
Hello Tomas!
I have a Voodoo 700 only for low RPM !
Wich settings are important , especially for low RPM .
my speeds : 1000-1250
Is there something to be noted in the rescue ? They should react in low speed fast!
Greeting Frank
 Post subject: Re: Voodoo700 - Low RPM!
PostPosted: Thu 05. May 2016 9:39:17
make sure that your Cyclic Ring will be not so high to not get a boom strike.
Also I recommend to set Flight Style to a higher values and Elevator Filter most probably too.
Little bit of Revomix (value 2-4) might be necessary.
PostPosted: Sun 15. May 2016 14:45:59
Ok, thanks!
What is the best Heli in "Setup with wizard" for my Voodoo700 for Low RPM?
(I am waiting for my Spirit Pro!)
Greeting Frank
