It is currently Sun 24. Nov 2024 7:52:03
PostPosted: Tue 20. Sep 2016 19:34:02
Hello, as mention before I just purchase a Triabolo 700 and have a Diabolo 550, im changing from BD3sx to Spirit Pro, will like to know for both helis, what setup should I use from the Model Presets, and what adjusted should I use, I recently install one in a Goblin Black Nitro and very please..
Triabolo 700
Flight Style: Soft 3D - Sport
Motor: Xnova XTS 4435-460
Pinion: 18T
Target Headspeed(s): 1200-1800HS
ESC: HW160a
Governor: HW Store Gov
BEC: HW internal 7.4v
Cyclic Servos: Savox SB-2282SG
Tail Servo: Savox SB-2283MG
Main Blades: NHP 680mm
TriTail Blades: NHP 110mm
Lipos: Revolextrix 5200 6S 40C
Diabolo 550
Motor: Xnova 4020-1200KV
Pinion: 20T
Target Headspeed(s): 1700-2300HS
ESC: HobbyWing platinum 100A v3
Cyclic Servos: MKS 9767
Tail Servo: MKS 9780
Main Blades: Cyclone 555mm
Tail Blades: Rail 80.6
Lipos: Pulse 6s 4500mAh 45C
Thank you.
PostPosted: Wed 21. Sep 2016 17:40:39
Hello
I recommend to set the following parameters.
Diabolo 550:
Sensor/Cyclic Gain: 60-65%
Sensor/Rudder Common Gain: 1.2x
Sensor/Rotation speed: 10, 10
Advanced/Elevator Filter: 3
Rudder Delay: 0
Pirouette Consistency: 170-175
Triabolo 700:
Sensor/Cyclic Gain: 50%
Sensor/Rudder Common Gain: 1.4x
Sensor/Rotation speed: 11, 10
Advanced/Elevator Filter: 3-4
Advanced/Cyclic Feed Forward: 4-5
Rudder Delay: 0
Pirouette Consistency: 180-190
Expo can be configured in your transmitter to 20-30% or as you like (for rudder, aileron, elevator).
Nice helicopters!
PostPosted: Wed 21. Sep 2016 19:17:45
Thank you very much, one las thing, when in wizard i should choose the default correct?
Will post Files when I finish them..
PostPosted: Thu 22. Sep 2016 15:26:39
gabs_mex wrote:
...one las thing, when in wizard i should choose the default correct?
That is still a mystery to me. Very easy to know what to do when the helicopter you are building is in the presets. But what do you do when your helicopter is not in the presets? Do you use a helicopter preset that most closely matches your helicopter size, or do you choose "default" helicopter?
PostPosted: Thu 22. Sep 2016 15:37:34
You can use default without any problem. You will rewrite the parameters with values that I have written, so basically it does not matter which profile you will select.
Default is recommended for helicopters that are not in the list.
Users browsing this forum: Bing [Bot] and 13 guests
