It is currently Sat 05. Apr 2025 19:36:10
 Post subject: Vibration level?
PostPosted: Wed 26. Apr 2023 14:04:35
Hi
Waht is an normal vibration level?
My Protos 380 has an vibration level of 8 while hovering is that normal?
Kind regards jens
 Post subject: Re: Vibration level?
PostPosted: Wed 26. Apr 2023 18:49:16
Hey.
I guess that's good number. On my goblin 380 with light 3D or fulling around with rescue I get numbers around 50. Model never crashed , balanced blades.
PostPosted: Thu 27. Apr 2023 18:50:22
There is a describtion what levels that is ok and not under the scope. But if you only have 8, thats almost low as you can get;)
PostPosted: Thu 27. Apr 2023 21:17:12
Hi and thanks for the answers. Do you have a link to thr description? Couldn’t find anything.
PostPosted: Tue 21. May 2024 17:40:35
Hi, I'm wondering if I understand the numbers of vibration level correctly.
In the manual we are talking about "level in percentage"
Vibration levels:
Vibrations up to 50% - vibrations at a normal and acceptable level
Vibrations between 50% and 90% - raised vibration levels
Vibrations exceeding 90% - extreme vibration levels
In the software, e.g. the analyzer, there is no "%" sign in the near of any vibration indicator.
https://manual.spirit-system.com/index. ... 3_1fen.png
--> Is every vibration indicator in the spirit software a percentage value (e.g. "9%" in the above picture)?
--> If we are talking about vibrations level e.g. "9" in the different forum posts, do we mean 9%?
--> So there is no different between "vibration level 9" and "vibrations 9%"?
Thank you so much for any clarification
